36 hawthorne seat post
spoker
5,502
Minneapolis, United States
how to remove seat post from a 36/37 hawthorne silver/aluminum frame?i dont see a clamp bolt
Reactions: Scout Evans
MEKANIXFIX
Apr 16, 2014
280
USA PR
Hola hi! Mine SK have the same system that the other fellow caber mentioned! The quill seat post works as same as the handlebar post! Loose the seat then loose the top bolt!! Recommend use PB blaster/ WD40 before trying! To prevent damage!! Good luck
Reactions: Foxclassics
Rivnut
1,611
Shawnee, United States
I've had a couple of stuck handlebar stems lately and I've found that I can usually get the wedge out by taking the stem out rethreading the bolt back into the wedge. Then I put a body puller slide hammer on the head of the bolt and give it a couple of good shocks with the hammer and the wedge breaks loose and slides out. Use a brass brush wheel on grinder motor and brush the wedge till all the rust is gone. Same method for getting rust off a seat post. Breaking the rust bond on a seat post can be overcome with my 18" pipe wrench.
If you can get the top part of the post out of the seat tube, you might be able to retread the bolt into the wedge and figure out a way to apply some quick shock force to it and break it the post loose. Steady pressure doesn't work, it needs to be shocked loose.
