38 Colson Screw Tank in yellow
Hawthornecrazy
38 Colson screw tank. Original yellow and black pins. I cleaned off a light layer of red spray paint with some left behind In the hard to get places and along the pinstripes where it seemed to be stuck a little better. Frame has quite a bit of missing paint. No seat missing one truss rod no rear rack no tires no front light. The grips are missing the jewels and do have some cracks. Pedals are pretty nice 10’s one the blocks are chewed up a bit. The crank and rear hub need to be service. Needs a new front axle. The bottom rear fender brace is cracked should be able to spot weld it with out causing any problems or could just leave it I don’t think it’s anything major. The front rim has rough rusty spot by the valve stem but should be useable. Chrome might clean up some.
Drop stand is in good condition the inside of the tank is very clean with no issues. All the spokes are there and the rims seem pretty straight. If you want more info pm me please. $1050 shipped from Minnesota to lower 48 PayPal for payment please. Thank you
1248187
1248188
1248189
1248190
1248191
1248192
1248194
1248196
1248197
1248198
1248199
1248201
1248202
