'62 Raleigh Sports with Dual Drive
3-speeder
Dec 26, 2017
571
Lansing, MI, United States
The "pit" was empty but not for long. I salvaged this cardboard from the recycling bin. It was on top of a double-wide pallet. It's perfect to contain all the little parts that want to roll away. Especially those little ball bearings in a Raleigh headset, right @morton? This is where I do my work. I call it the pit.
1133143
Today I started on the '62 Sports that I posted here:
3-speeder
Dec 26, 2017
571
First step that I do is remove the accessories. Then I remove the grips and loosen up the brake levers so they'll slide off after I remove the wheels. I have my bins and trays ready to store the parts as they come off. Old coffee bins come in handy. I use the lids to keep parts together as they come off and for storing some cleaned parts as they air dry.
1133144
1133145
1133146
1133147
1133148
1133149
1133150
morton
1,647
York, United States
Love those Raleighs.....well built, look good and last forever!
But those 48 (or is it 46) loose head bearings and cottered cranks.......not to be worked on with children within shouting distance. :fearscream:
Anyway, you have nice bike done well and ready for another 60 years!
3-speeder
Dec 26, 2017
571
Got a bit more disassembly done. It's going well. Bike is in great shape. I haven't worked on a Raleigh from this era. Late sixties and early seventies bikes are a little different. I haven't seen front wheel nuts with a shoulder that sets through the washer and into the fork. The inside of the rims looks brand new. Before I attempt the cotter pin removal I fill the void around it with oil and let it soak overnight. One side at a time. Seems to help.
1133559
1133561
1133562
1133563
1133564
1133566
1133567
Hammerhead
Oct 5, 2018
863
Franklin,NH
Nice, looks to be in very good shape and capable hands. Great looking project.
Hammerhead
Reactions: 3-speeder
3-speeder
Dec 26, 2017
571
Taking apart the front hub I noticed differences from later models. The cones on both sides of the axle are the same. On later models the fixed cone is round and not squared for a wrench. The axle on this one has a slot cut for a toothed washer. Little bit different.
Got the cotter pins out and took apart the bottom bracket. The proper tools help. Thanks you to http://bikesmithdesign.com for the pin removal tool and the fixed cup removal tool. Soaking in LA's Totally Awesome gets the gunk off and I finish with a brass brush, tooth brush and hot water rinse. I dry em off in front of my fan. I'm really looking forward to the dual drive hub.
1135340
1135341
1135345
1135346
1135347
1135348
3-speeder
Dec 26, 2017
571
The 3-cog cassette is a beast! Built like a tank! All one piece*. The driver looks taller to accommodate it.
Edit: *Upon closer inspection it appears maybe it was more than one piece, however, good luck getting it apart now! :)
1136266
1136267
1136269
3-speeder
Dec 26, 2017
571
Well it appears the driver is the same size. It's already a pita to get the spring clip on, even more so in the cramped area inside that cog cluster. I have all the ball bearings and adjacent parts degreased, cleaned and ready to go. Next I'll detail all the other small bits. I'll take my time on that Benelux derailleur when I get to it. I have found a great way to clean the cable housing.... stay tuned for that. The cleaned and regreased SA hub is spinning like a top.
1139836
1139837
1139838
1139839
3-speeder
Dec 26, 2017
571
I cleaned up the brakes and cables. I tried the Mr Clean Magic Eraser on the cable housing on my last rehab and found it worked great. They're just like a sponge but somehow do a good job at brightening. Might be able to notice in the before and after pics? I have been cleaning up the smaller bits and mostly have them all clean. The chrome polished up nicely and I also have everything but the frame polished and waxed. Today I started on the Benelux derailleur. I'm servicing the bearings inside the small chain tensioner wheels. I'm doing one little wheel at a time to keep their orientation straight. Getting close to my favorite part....... reassembly.
1144252
1144253
1144254
1144255
1144256
1144257
1144258
1144259
3-speeder
Dec 26, 2017
571
Hitting the home stretch now. I decided to add a traditional Raleigh lamp bracket. I'm not going to use the bottle generator and lighting system that was on the bike. Not sure what I will use yet but I'm switching the thick toothed washer in the headset assembly with the lamp bracket. Got the "Cyclo" derailleur all cleaned up. Fresh bearings and grease. 15 of the little 1/8" buggers in each cog/wheel. Rolling smooth now. The only job left before reassembly is to clean, polish, and wax the the frame. Might be putting this beauty back together this weekend.
1146767
1146768
1146769
1146770
1146771
3-speeder
Dec 26, 2017
571
Well I finally got the entire bike polished and waxed. Now I'm starting the reassembly. Got the headset back together. Next will be the bottom bracket. Can anyone tell me what the little round bump-out on the chainstay is for? Maybe @SirMike1983 knows? Haven't seen that before.
1151504
1151505
1151506
1151507
jimbo53
Jul 17, 2015
888
Charlotte NC
It's for the pass-through bolt to mount a full-cover chaincase. They brazed the mounts onto most of the frames for quite a few years, even if the frame got a hockeystick guard in the end.
Good to know. Always wondered what that lug was for.
3-speeder
Dec 26, 2017
571
I got a little more work done tonight and now I'm done with the grease. I like getting the fresh grease in there and getting that perfect adjustment. The fine balance of free spinning and not too much play. I used two different types of grease. I'm liking the Teflon for how it stays put but like the polylube as well. The stand was over tightened at some point and crunched the chain stay slightly but not horrible. I wasn't sure about the old tires. They are a little stiff. I like the Scwalbe Delta Cruiser tire and had a set with the safety reflective stripe but maybe I'll see if I can find a set of em with white walls.
1151890
1151891
1151892
1151893
1151894
1151895
1151896
3-speeder
Dec 26, 2017
571
Got it all together. Didn't put any of the accessories back on except for the rear rack. I may end up putting the speedo back on because it sure was clean and shiny. I switched out the kickstand for a dual one. I like how the bike sits on it. Got a new B66 on it too. I'll get more pictures when I get it out for a ride. It is supposed to rain this week and I'll wait for that to wash more of the road salt away.
1152779
