'64 Columbia Fire Bolt; Rat Rod
Superman1984
I bought @jimbo53 's 1964 Columbia Fire Bolt he built as this pretty cool Rat:cool:
1383062
I took "the creature" for a Good mile ride this mornin' & it rides pretty nice once I lowered the seat a hair closer to low rider status.
I intend to make a few little changes here & there but Nothing too drastic or undo able;
1st I think a Monarch dog leg is in order as it'll fit the patina on the peppered chrome & of course the oL'School Kool look
2nd Since it's a Columbia I think the Columbia Superb White Wall tires I have will look at home once I dirty them & give'em a little patina
#3 L.E.D conversion to the existing head light & maybe 2 mini L.E.D 100 lumen flashlights in a Bug eye fashion for the tank for night cruises & since they're damn near impossible to find
#4 Stop Brake light
#5 I have some ideas I want to try with an oL'aged piece of Copper sheeting I pulled off a house for inserts between the rack & tank; #'64, Columbia Script & or a finalized name.
Debating some Black Light or Green L.E.D glow with some other ideas but not too sure how everything will tie in together 'til I start making it happen.
I had a '64 Ford Fairlane 500 so I'm kinda thinkin' Fairlane might be a fitting name since that year they removed the fins & it too was Originally Red/Burgundy.
Moarrr pics with Every Little Change Comin' Soon!
Any ideas & criticisms Welcome ....
I don’t need to tell you to post more pics as you personalize it. That is the fun part...Making it “yours”!
1383424
Got the tires on & semi adjusted at about 40-44 psi before the rain started. Not a lot of clearance/wiggle room. Jim said he caught hell & I can see why even more so with the way these tires are designed & still have the nipples on them.
I am kinda on the fence about using coffee/tea grounds & or coffee bean acrylic paint to stain'em. Has anyone here done it? The white pins & Columbia script are still pretty white in person so if you guys have an opinion toss it out for me.
Tires are kinda dirty from handling & sitting in the garage but I didn't feel up to makin' anymore of a mess in there to clean or stain'em. Haven't felt great lately; damn joints & hip pain :rolleyes:
I am planning to use a key chain 8 ball to the kickstand as a foot to keep it up right better to lessen lean or see if I can make an OCC Stingray dual leg stand clear & Not lift it so high.
Playing with this idea; the front fender will be the easiest but Schwinn box store Delmar/Windwood etc balloon fenders - sanding, polishing & will maybe add some hot rod striping or go with a Shelby Red/White tip scheme. I know it's not finished but any opinions ?
1395250
Ok so both modern day Schwinn balloon box store fenders are pretty much mocked up; I had to use what I have on hand for braces (front wald) & (rear ebay universal) & Nothing is 100% adjusted & Modified to the extent of final.
1395847
What does Anyone & Everyone feel or think about it?
I am Diggin' It & seein' the potential Even Moarrr!
Hell Jus' mocking up & centering the wheel I have more wiggle room side to side every where but the tight curve of the U bends. I may even be able to remedy that pinch area by notching the fenders there as the edges are are pretty heavily rolled & with some actual vintage braces with a little dremel action I should be able to pull them down for an All Around White Wall Tuck.
