66 Bendix 2 speed hub blue band (help me)
Discussion in 'The Workshop' started by Lance Vangraham, Aug 8, 2017.
  1. #1 Posted Aug 8, 2017
    Jun 16, 2016
    214
    253
    Bellingham WA
    My current stingray project has an automatic 2 speed kick back hub on it. It shifts and works but is noisy and doesn't want to coast well. Took it to my LBS, he says he needs a special tool to get it apart. I have read you can take these apart from the brake arm side if you can't get that lock nut off. Any one done this? Any tips? He can't help me so I guess I'm going to tackle the job. Never done a 2 speed yet. I have a diagram on the order of parts installed. Almost curious if I can just open it up a bit and get some lube in there. Thanks in advance!
  2. #2 Posted Aug 8, 2017
    Jul 21, 2013
    1,847
    1,544
    Waterford, NY
    yes
  3. #3 Posted Aug 8, 2017
    Moderator Staff Member
    Jul 11, 2012
    10,226
    10,837
    Monrovia, CA 91016
    Lance Vangraham likes this.
  4. #4 Posted Aug 8, 2017
    Jun 16, 2016
    214
    253
    Bellingham WA
  5. #5 Posted Aug 8, 2017
    Jul 11, 2012
    10,226
    10,837
    Monrovia, CA 91016
    no, I think it's best to do it the way Bendix recommended.
    Bearing adjustment is made via the lock nut that requires the special tool.
  6. #6 Posted Aug 8, 2017
    Jun 16, 2016
    214
    253
    Bellingham WA
    Gotcha. My lbs says he can open it up but has no access to parts if they need it. So I guess it is up to me at this point
  7. #7 Posted Aug 8, 2017
    Jul 11, 2012
    10,226
    10,837
    Monrovia, CA 91016
    You can do it. :sunglasses:
  8. #8 Posted Aug 8, 2017
    Jun 16, 2016
    214
    253
    Bellingham WA
    Got it back and tore it down. My "special tool" was a pair of 90° bent snap ring pliers. After clean up I noticed I have a bad bearing ring on the gear side of the wheel bearing. And I am missing 2 o the little free bearings pictured as well. Any one know where to get parts? Was a lot easier to tear down than I thought.
    mike j and rustjunkie like this.
  9. #9 Posted Aug 8, 2017
    Jul 11, 2012
    10,226
    10,837
    Monrovia, CA 91016
    Nice going :smilecat:
    The bearing cages can be reused: push out the old bearings and pop new ones in. Also replace the 11 loose ball bearings. Your LBS should have them, if not get 'em on eBay, grade 8 chrome steel ball bearings.
  10. #10 Posted Aug 8, 2017
    Jun 16, 2016
    214
    253
    Bellingham WA
    awesome thanks for the lead, I appreciate it! ill check with the guys down the street tomorrow! once i get this done the rest of the bike will be a breeze, ill post pictures once i finish it up.
    rustjunkie likes this.
  11. #11 Posted Aug 9, 2017
    Jun 16, 2016
    214
    253
    Bellingham WA
    Is there a size on these bearings?
  12. #12 Posted Aug 9, 2017
    Nov 2, 2016
    19
    8
    Clementon, United States
    The 11 loose balls are 1/4". Not sure of the size of the others, but they are available as complete races on ebay if you want to go that route.
  13. #13 Posted Aug 9, 2017
    Jun 16, 2016
    214
    253
    Bellingham WA
    I went to my lbs and got the bearings. Will be going back together tonight I hope.
  14. #14 Posted Aug 9, 2017
    Jun 16, 2016
    214
    253
    Bellingham WA
    Done and done. Replaced bearings cleaned and lubed it all. The real test will be when I finish the bike up.
  15. #15 Posted Aug 13, 2017
    Jun 16, 2016
    214
    253
    Bellingham WA
    Here she is all finished up. Hub is a little growly in low gear. But the bike rides great and is super sexy!
    RustySprockets and rustjunkie like this.
