67 CT-2 Cycle truck
Rusty Klunker
I've had this bike a couple years but right now all projects are coming due.
It was rough and not complete but "cheap" as far as CTs go. I knew there was frame damage but thought I could fix that. Seller said it had Araya rims but they looked like S-2s in the pictures. So my hope was that it had S-2s and the stem was straight... so much for that.
Stem is bent, back wheel is an Araya, front is an S-2 but has 5 very large curb dings. Two of the dings are across from each other and kinked the flat of the rim at a spoke hole. Even if I tried to work them out I'm not sure how true I can get it.
They must have rode it with the frame broken for a while, the left side chain stay is gouged pretty deep from the wheel and tire rubbing it. Its been rode hard and put away wet. I thought it was bad till I saw @tacochris 's and his build gave me some ideas.
Originally I was going to grind out the old repair welds at the dropout, make a half moon splint in the cavity and weld it up. But chris gave me the idea to replace the rear triangle. Been welded for a few weeks and most of the welds are cleaned up. I wanted to mock it up, put it together and test ride it, never rode one. Went to pull the seat post as its all chewed up but it was stuck,.. stuck like I've never had! I've made a tool for this but the CT wasn't haven it. Filled the seat mast up and had it soaking for weeks, broke the tool a couple times but finally got that out. So that stopped me from cleaning up the welds.
When I picked this up I went to take the pedals off. Well the left side snapped off clean with the threads in the crank. ... thought no biggie, I'll get to it later.
Rusty Klunker
Hit the wrong key and that posted to quick... lol
But where I'm at, Left hand thread pedal how do I get this out? Had the great idea to drill and tap it right hand thread 1/4-20, tightening that should unscrew it right... WRONG. Been soaking this for weeks, didn't want to use heat but I have (just with propane, no longer have an Oxy set up). Tried heating it up and adding wax, nothing. Tried allen wrench on one side pipe wrench on the threads on the other... nothing. After breaking a couple of those drilled and taped it to 5/16. Tried all the same tricks, still not budging. Now its taped to 3/8, have to get some cap screws tomorrow. Any ideas on how to get this pedal out>
1663006
tacochris
Man im honored i could inspire you! Thats why i post my crazy travels and wild ideas! If it saves one more bike its worth it.
As far as the pedal goes, i have had great luck with heating it up almost to the point of getting it red and then immediately spraying it down with water. The rapid cooling has a knack of shocking the rust loose in most cases for me.
Now some metal nerds will tell you the rapid cooling will damage the cast crank arms and make them prone to failing later but in this case it would seem to be worth the risk. Give it a shot and see how it goes.
Rusty Klunker
You performed miracles with yours!
Mine turned out great, once its painted you'll never know. I wanted the insides of the tubes cleaned/sandblasted for a good weld. So I took the triangle to a local auto resto shop and told them to just do the inside, leave the yellow paint (I wanted that look for a bit). He did it while I waited. When he came back all the yellow paint was gone and the inside was still rusty. He didn't charge me anything so I didn't know what to say, just thanked him and left.
I here you with the heat I don't really want to use it, but all I have is propane. I've tried heating it and trying to spray PB blaster at just the plug and watched it soak in the threads. I can't believe its that stuck! Its not like its bottomed out and jammed in a hole. The heads not stuck on a face... there is no head. I've cut the end off the allen so it has good bite. Had a pipe on the allen this thing is not moving. I have an allen socket for the 3/8 bolt. I'll try a breaker bar on that.
Rusty Klunker
I don't know what I was thinking originally. Once I saw what you did it was one of those smack your head moments.
Its not perfect, it still shows battle scars that I'm not going to remove. It has things welded that were originally electroforged. But at worst I saved a cycle truck frame and there is a market for them.
tacochris
Saved is saved man! It can live on as the thing it was always meant to be, rolling art!
