67 CT-2 Cycle truck
Rusty Klunker
Thats been a thought too. Havent seen metal blades for one. There isnt much metal left now as its tapped to 3/8 - 16.
Rusty Klunker
This had really slowed things down. The tool was made from just scrap on the job and a top tube from a trash picked bike. I've pulled many of stuck schwinn seat posts with it.
Rusty Klunker
At one point I thought it was working. I'm cranking on the wrench and its turning, thought finally. But no, I was just crushing and bending the tool. Then switched to a piece of 1" ridgid conduit, pulled the threads out of nuts, stretched and broke a few pieces of all thread. This had always worked perfectly before but not on this one.
Rusty Klunker
The bike was upside down for a few weeks filled with PB blaster so nothing else was getting done to it. Any time I was near it I would give the wrench a 1/2 turn it just wasn't letting go. Tried heat on the seat mast, nothing! I was about to cut the tube down and cut notches in it pull it out in pieces. But one last try for the tool. I ordered fine thread grade 8 all thread from McMaster Carr, a rod coupling for in the tube and a larger hex rod coupling for the top. The 9/16 nuts were mushrooming into the square washers, just drag and cutting up the threads. Finally that worked but it had been soaking for weeks.
Skiroule69
As Willworkforparts mentioned, I've also had success drilling a stuck fastener out to just shy of the threads. The heat from the bit will usually loosen things and then you can scrape what's left in the threads out with a pocket knife.
