67 grip question
pedal4416
1,893
37
Bryan, TX, USA
I'm in need of some grips for my 67 coppertone deluxe. Would coppertone be correct? If so I'm assuming I need the chubby style because they seem to be more expensive!
Here's the 2 styles I keep finding, which ones are right?
Sep 2, 2012
11,611
Central Arizona
Those two sets look the same to me. Part number 7925 Coppertone. Same "chubby" grips that are on many other 1967 Coppertone models. Color shade will vary due to weathering and age, and the lighting used for the pictures.
pedal4416
1,893
37
Bryan, TX, USA
They are slightly different, bottom set has a deeper more tear drop shape and the last finger groove is longer. It looks chubbier. The top is shallower, more of a spear shaped logo and evenly spaced fingers. I'd like to get the bike as close to correct as possible.
pedal4416
1,893
37
Bryan, TX, USA
Chubby should be correct for 67 right? The slim was later years?
Schwinn499
2,132
Monrovia, CA, United States
Had a coppertone 67 Racer with the slimlines, had a coppertone 67 collegiate with the chubbys. I'd say chubbies on a deluxe bike.
Sep 2, 2012
11,611
Central Arizona
It seems that Schwinn has the same Factory Number on the grips (7925) for the vast majority of the bikes in 1967, just different colors. Makes no difference what model, Sting Ray, Heavy Duty, Breeze etc.. This is not true for the 66 and earlier models though. o_O Same size/age kids riding Stings Rays and middleweights or lightweights, so I see no reason why they would use a skinnier grip from one model to the next. On the smaller juvenile bikes I can see them using the slimlines.
Schwinn499
2,132
Don't some of the early rays have white chubbies? Not my area of not-an-expertise so I could be very wrong. A lot of small detail stuff changed in 67 from what I've noticed.
Sep 2, 2012
11,611
Central Arizona
I grew up during the Sting Ray rage and the colored glitter grips were first seen as an on the shelf custom Schwinn dealer part prior to being factory standard issue, which seems to have started with the 1967 models. I believe chubs were the norm on all the little big boy bikes when the glitter pieces became factory issue. The 64 Jags used the same grip as the 64 Sting Rays so I'd say the Rays came with chubs, white or whatever flavor of the year.
videoranger
Dec 19, 2006
645
Omaha, United States
I have a '67 Deluxe and a '67 standard Ray Copper tone (both stock) and they both have the slimline sparkle grips like the second picture.
Metacortex
Sep 22, 2012
888
The Matrix
According to the Sept. 1967 Schwinn Reporter the Slim-Line grips (#7926) were introduced in production around Sept. 1967 in Violet, Campus Green, Sky Blue, Coppertone, Black and Flamboyant Red, replacing the #7925 glitter, #7916 Black and #7952 White "chubby" grips.
Overhauler
Feb 15, 2011
448
Central , Il
My 64 and 65 original deluxe stingrays both have white chubbies.
Lee
pedal4416
1,893
37
Bryan, TX, USA
Thank you all for the responses. I'd rather have chubbies cause they feel better(insert jokes here)but I'll go slimline cause they're cheaper!
pedal4416
1,893
37
Bryan, TX, USA
I believe my bike is a September 67. I'll look again after my ride through the fireworks in my crazy neighborhood.
