67 stingray seat
It's a bit longer and a little narrower in the nose area then the normal stingray seat. If you had em side by side you'd tell right away which one is a 67 long nose. Also called "hard pan" or "hard side" as they don't have much padding. Mostly seen on 67 Fastbacks. Maybe someone can post a picture for you.
Ebay has one # 335260331751 seller "Duckmandean"
It's a bit longer and a little narrower in the nose area then the normal stingray seat. If you had em side by side you'd tell right away which one is a 67 long nose. Also called "hard pan" as they don't have much padding. Mostly seen on 67 Fastbacks. Maybe some can post a picture for you.
Thanks Tommy
