Schwinny
I recently went cageless BB on a couple of my once piece crank bikes. I ended up with a lot of extra Bearing Balls. If any one would like to do this I have all you will need.
These are 2x harder than stock chrome balls and 4x harder than the old black non-chrome style. 8mm is a bit smaller than many BB caged balls so check your size. I think they will work no matter what, your cones will just be a bit further in meaning you would need a spacing washer on the drive side to take up a little slack if you currently have a 9 or 10 ball cage. These replaced the balls in a 12 ball cage. I had to add 2 for a total of 14 on each side.
As a "trick of the week" It is supposed to reduce friction and be lighter weight. The BB spins super fast and for a long time when freewheeling afer I installed them. It seemed damn near frictionless but who can tell? I weighed everything and it was .8 grams lighter per side. Woopdeee. The cages were pretty light but each of the 12 balls do drag on the side of the cage they are pressed into as they spin around.
I have a couple hundred.
I will send out 30 for $12 shipping included.
