MarkKBike
I'm sure we have all run into the annoyance when cutting cables, and had them unravel on us.
Prior to cutting a break or derailleur cable I put a few drops of super glue on the area to be cut, and wipe off the extra with a paper towel. I then use a dremmel cutting wheel to make a nice clean cut. The super glue prevents it from unraveling on me. (I have a park tool made for this, but the dremmel works better). I also use the dremmel to cut housing.
If your using new cables you probably don't have to worry about this happening, but I sometimes reuse cables that are in nice condition and this allows me to easily feed previously cut cables back though the housing, Sometimes after the cable is cut, I add another drop back on to the end. And then when its time to crimp a end cap on, another drop gets put on before the cap is added.
The process ends up saving me some time.
