Barnegatbicycles
Those hubs ! They should be Thor. If so there will have the word Thor engraved on the rear hub opposite of the gear.
Questions:
I have seen that Pierce had threaded bottom brackets in later years. The bottom bracket (see photos) was threaded to accept the bearing cups and spindle from a Bianchi (marked). Is it possible that the bottom bracket has been re-tapped to accept this or would it be axle to accept both? I am concerned about standard to mm thread pitch.
I do not believe that your hanger bracket is threaded, it looks as if you have threaded bearing cups. Your cups are similar to the ones on my BR model Amateur Sprint Racer, except that mine are not threaded. One thing I have found about Pierce machines is that they did not typically use conventional sizes on things, for example, my steer tube is 1-1/16" as opposed to the standard 1" steer tubes on most other bicycles.
The brazing where the seat tube and down tube look different where they attach to the BB from others I have seen. Is this reinforced brazing, or signs that the BB has been replaced?
Your brazing looks like it is all factory, as #New Mexico Brant noted, your Carmine red paint all looks like factory paint.
When cleaning, what is the preferred method of rust removal from the frame?
There are many methods out there, OA is one a lot of people use, however as your bike is Carmine red, it isn't recommended as it doesn't do well with reds.
On my Pierce, I used a polishing compound, very lightly abrasive to address the small spots of rust, then many coats of carnauba wax on top of it to protect the paint. (in my opinion my paint looks really good).
Does anyone know anything about the pull-through hubs on the rims? They are matched to each other, but the rims are different.
the bike could have had an accident over the years and a rim replaced, using the original hubs.. just a wild a** guess.
What is the little bracket/hanger for on the stem?
could have been for a light, or to hang a water bottle from, that is another guess.
Lastly, is it possible this bike was set up for road racing? I only ask this because of the frame reinforcements and the frame-mounted pump brackets. Would it still use a fixed hub?
It very well could have been set up for road racing, and the rear hub options were either 'fixed' or 'coaster'. The coaster brake set up was typically about $5 more.
All in all, you have a really nice bicycle, if you chose to clean it up and polish it, it should pop nicely.
This is what mine looks like when it is freshly polished.
in it's show form.
in it's everyday rider form, and I try to ride it everyday.
Also, they are surprisingly light. My frame and fork, weighs 6.5 pounds. The bike set up in everyday riding condition is just under 28 pounds.
Not paint, but rust remover. I wasn't clear enough.don't touch up the paint.... brushed dabbed.....your bike, my opinion only
Nice Stayer you have there.Hi Austin,
I've been meaning to join here for a while, and this bike finally got me to...
The reinforcements on the frame are something you'd see on a Motorpacing bike, and the clip on the stem would be the upper clip for a stem support rod.
Most also has a seat support, and the wear on the paint right under the front end of the seat looks about right for a clamp that might have been loose for a while.
I've been looking for pics of one like this, which I think I've seen before, but I can't find it.
Pacing bikes are pretty special, and would have almost all been custom built. They got used fairly hard, and after a point, some got converted to being normal bikes either for training or just warmups.
They also got used for a long time, even much more recently.
I have a couple, one from the 20's or 30's And one from the 80's
The older one had a similar conversion, but they'd even removed the racing bars and put on flat bars. It had also been crashed heavily and had the steerer repaired with a solid steel slug and pins where it had cracked.
Here's a before and after pic of it as I bought it, and once I got it mostly fixed up. I don't have a stem support, as the fork isn't tapped for one It's original, so it was probably raced without it.
Steve Birmingham
Great images! Here is a good spot to post more Pierce: riders, racing, pacingStayers deserve a thread all of there own, although i will hijack this with a few photos.
Hi Austin,
Steve Birmingham
