10~18kustoms
Picked up these two Monark pre-war frames at Haysville this weekend, and as usual I can't make any since out of the serial numbers using the widely inaccurate Monark serial number charts that are floating around.
I'm guessing the Flo-Cycle frame number 17838 is probably '36 or 37, and most likely '37 if the # chart is accurate? I am also intrigued by the upside-down 1 & 8's. Was it almost 5 on a Friday?
Next one appears to be an early Rocket motorbike (hanging tank) frame with the serial number 116273 stamped in small numbers on the right rear dropout. This one is really confusing since the serial number falls in the ? on the chart between '42 and 46. I always thought the wider hanging tank frame was discontinued in 39 or early 40 and the narrower bar frame was 40-early 42?
Any help or observations would be greatly appreciated!
