Antique New Atherton TOC Coaster Brake Rear Hub Arm
szathmarig
I'm just looking for the arm like this, the later version called New Atherton.
Those brake arms clearly read "New" -
perhaps F.C. Atherton had a 'middle version' stamped with the 1907 date (an improvement?).
The later (last?) Atherton design appears to have 1902 stamped on the brake arm,
(in some examples).
An older Shimano brake arm might be used as a temporary workaround fix, without need for filing or grinding (slightly loose fit in long dimension).
Older Shimano "Types" B or D (or A?); might be shimmed in curved dimension for a tighter fit.
"Shimatherton".
