yeshoney
THis is it so far.
Building a custom bike is never without its challenges. Trying to put parts together that did not leave the factory as such is like going 15 rounds with Muhamad Ali. My first choice for a sprocket did not work with the chainguard - and that was before I even tried to mount the chainguard. Two sprockets later I had to take this one off a bike that I will eventually paprt out anyway, but it was at the back of the heard so i had to play valet and move bikes around to get to it, UGH! Get the sprocket on the crank, mount the crank and the driveline doesn't line up. Shim the sprocket. Still not good enough. Swap out the rear sprocket for a less offset one. Still not right so I flip it over. As good as that will get. Try to fin a chain for a 56 tooth front sprocket and a 22 tooth rear and BOING! Everything is too short. So i make one but the length is too long to keep the axle at the end of the drop out so I take out the two links and then the chain rubs the fender on the top AND the bottom. That will get fixed tomorrow!!! For now this is it. HOpe you like my choices for sprocket and guard.
Joe
Joe
