Bearing cone B.B. restoration?
Ed Minas
Jun 25, 2016
391
229
66
Farmington, United States
#1
I am so close to being able to ride my 1911 Iver, but the B.B. bearing cone is badly pitted and is missing a few chunks. So what have other cabers done in a situation like this?
Has any body had any luck with repairing with metal spraying and then machining? Brazing then machining?
All suggestions appreciated
Thanks in advance.
hoofhearted
Saint Lactose The Tolerant
Jan 20, 2010
3,774
5,299
Fairborn, Ohio
#3
Ed ... how about some close-up fotos of the bearing.
Could be a CABEr has something that could be used.
Alternatively ... these are some of the consideration
points you and a tool-maker will need to process ......
Type of carbon steel that is appropriate, and a heat-treating
process (annealing, hardening, tempering) appropriate
to the type of steel ... and within that category -- an approp-
riate tempering level that will leave the steel at a hardness
that is lacking in brittleness ... and, at the same time, absent
of softness -- hopefully matching the hardness of the ball-
bearings.
From my own experience, I would have made that cone out
of JB Weld, then, chuck it in a lathe ... but I started watching
Forged In Fire on the History Channel.
Am not trying to diminish you enthusiasm ... I believe a remake
of your cone is do-able.
Go visit a local machine-shop.
...... patric
Ed Minas
Jun 25, 2016
391
229
66
#6
Thank you so much for all the input it is very helpful. Unfortunately I gave the piece to a friend who was going to take to his favorite machinist so I can’t post a picture. I haven’t heard anything yet but as soon as I do I will post a response and post a picture.
Ed Minas
Jun 25, 2016
391
229
66
#7
Thanks once again for all the input. Here is a picture of the BB bearing cone I need to either find or have machined. It is the side that locks the spocket gear against the crank arm and is for a 1911 Iver Johnson. A 1913 and later will not work as the recess is too deep.
bikejunk
Nov 1, 2014
530
167
55
passaic NJ
#9
I agree with the above unless you are going to ride across the USA or break a land speed record that race is fine -you just might have to replace the ball bearings every 1,000 miles instead of every 5,000 ----My 1892 Victor BB is about the same as what you showed no grinding or clicking sounds yet after about 300 miles
Handyman
1,208
1,314
Fitchburg, MA
#10
I was hoping to help out Ed with an Iver BB cone but to my surprise, the one he sent me was different than anything I have. #1 and #3 are mine, #2 is Ed's. The base of the cone on #1 and #2 are the same, but the base on #3 is much thicker. #1 and #3 have threads in the center part of the cone, #2 has threads in a recessed area on the rear of the cone. I tried , in the last pic of the single cone, to show the recessed area of Ed's cone that contains the threads. . Maybe someone can help him with the correct part using these pics.......................Pete in Fitchburg
Ed Minas
Jun 25, 2016
391
229
66
#11
Thanks Pete, your pictures and explaination are super helpful. I hope someone has what I need.
