Bending Schwinn Steel
pelletman
That steel is 1010. It is on par with rebar or melted car bodies. Not an alloy, just a cheap, easily welded steel. It is easily worked for a minor bend like that.
You shouldn’t have to heat it to bend it to where you need it to be. If you have a custom exhaust shop with a hydraulic tubing bender, close by, you can probably slip him a few bucks, and he will use the expander collet and make the frame perfect. But, working it with hand tools will work, also.
Good luck.
Ted
I like the pipe expander idea. They have manual ones you can probably pick up cheap, but I don't know if the go that small. Kind of a round wedge type affair
Any kind of over expanding of the head tube at the bearing cup location will give you one big headache with a loose fitting cup.
WillWork4Parts
Time for some recreational maintenance...
1706119
Fresh Schwinn head tube with little to no value. ☝️
1706120
Oops!
That was plummetting from shoulder height onto the door mat/concrete underneath, twice. Didn't feel that was enough for what I wanted to show was repairable. So, I hit it with the dead-blow hammer a couple more times. Nice flat spot!
1706121
Use a 1/2" drive extension and the largest possible socket that will fit into your closed up head tube. Upsize your socket as you go. Did this one with a 7/8" and 15/16" socket. Different manufacturers' sockets vary in diameter, and you will have to choose your own tight fit for the job.
1706122
Make sure the lower end of your socket wedges against the meatiest formed part of the head tube and you won't have to worry about other parts warping, just your flat spot.
1706123
Monitor your progress until "it looks pretty close" and don't go any further.
Wedge your original cup (or least favorite ugly one if you're really that worried about it) started on the dent side first, and then tap it in. Alternately, if you have an exerciser taken apart like this one, and have this lower cup still laying around, use it before the final fit of your original cup.
1706136
1706137
Even the part where the head tube met the concrete left minimal visible damage, a testament to Schwinn Quality!
1706139
1706140
As a side note, not sure why I hadn't used this socket setup for knocking cups out before. Plenty of weight behind it, perfectly aligned, and there's no "slipping through" before the cup comes out! Just hold onto the cup so you don't lose it and end up with a flying piece of steel aimed at your big toe... . .
SJ_BIKER
Riding a 41 Super Deluxe
Had some luck this morning. Started to strike the bent area with hammer and round tip rod I have...then muscled it more with a crescent wrench. And when the cup was close to getting in there...I used a a newer style cone and slowly tapped it in...worked ok back to shape
