coasterbrakejunkie1969
The hubs is peculiar in that it is spring loaded unlike a regular 3 speed hub. The 2 speed in always in low gear and the shifter pushes and hoilds the hub into high gear. The shifter is very specific it has almost a lever action and kind of locks itself in the correct position to hold it in high. I do not think a regular shifter work in that it would not be able to hold it in place as it would not have enough friction to counter the strength of the spring and therefor would continue to slip into low. I will take some pics of mine in a bit. The cable on the correct shifter has a metal sheathing not plastic so it can be clamped securely to the frame to hold it while the cable inside moves the hub actuator. They are not all that hard to find but can be pricey. I have purchased a cable and an actuator knuckle for the axel from feebay but I do not think they make an actual shifter switch. I would suggest placing an add in wanted section or maybe contact @Gordon he seems to always have the parts I look for and great prices. I will get you pics later I hope I did not confuse you further. I have both types of 2 speed manual like were talking about and automatic when you pedal backwards to switch and the manual is my favorite.
