examined bicycle when first posted here at lightweights forum as a for sale item
thought it best not to comment since it was for sale
machine quite a "tin-o'-worms" due to the numerous changements effected
frame -
constructed with Agrati "BRANZA" (place name) pattern lugset nr. 000.8030/U
upper head lug item nr. 000.8034
lower head lug item nr. 000.8033
seat lug item nr. 022.8039
bottom bracket shell part of "BRIANZA" ensemble as well but do not have nr.
crown likely Agrati as well but do not have name/number
pillar a clue to frame:
it is one of many non-original fittings and is size 26.2mm
https://thecabe.com/forum/attachments/20190514_102719-jpg.998198/
if you look closely at its markings, font, and closed underside of the clamp portion it is clear to be well later than cycle. there were Campag Record pillars contemporaneous to cycle but they exhibited small differences. it may be about the same era as chainset - more on that below...
this 26.2 size is indicative of a quality plain gauge tubeset such as one from Falck
when combined with headset, this is suggestive of a model about two down from the top, a midliner
original pillar at this level of model at this time would have been plain steel
on to the fitments -
original fittings include headset, stem, likely bar, brakeset and possibly rear mech
expect bar to be marked "AMBROSIO CHAMPION"
brakeset a helpful date clue as last year for this early type Weinmann Vainqueur set is about 1962
Ambrosio
regolabile handlebar stem worth a small fortune...
quite possible wheels original. axle locknuts can be checked for a date, if at all near to 1960 they may be original
http://www.peterbrueggeman.com/cr/catalogues/olmo-ssn-dating-locknut.jpg
chainset clearly too late for cycle - even if cycle had come from factory with Campag Record chainset it would have been 151mm BCD rather than the 144 we see here. original set likely something such as Magistroni L. Senior three-arm cottered steel.
http://www.blackbirdsf.org/magistroni/
there is a chance that the original Magistroni cups may still be in the shell...
original pedals would have likely been a model of Sheffield quill. if mfr went with quality they might have fitted model 613. more commonly, a machine at this level would have received the Sprint.
http://velobase.com/ViewComponent.aspx?i.d.=684E1365-6D58-4C46-8575-57C7C16AE9D3&Enum=109&AbsPos=278
http://velobase.com/ViewComponent.aspx?i.d.=3F39EEB3-39E2-41F7-8539-343671E9F068&Enum=109&AbsPos=279
original gear ensemble would have been Campag Gran Sport: rear mech, front mech and shift levers
https://cycling-passion.com/wp-content/uploads/2013/06/Campagnolo-Gran-Sport-gruppo-1953.jpg
dunno which looks more out-of-place the Huret 600 Allvit front mech or the Maeda downtube controls!
have no knowledge of the Benotto marque so cannot assist there
one point which might be of interest for you to explore is the Mexico operation
have never known if Benotto had their own facility there, what years it was in operation or if the Mexico bicycles were simply contract done by ACER-MEX
