Bent Crank Arm
Junkman Bob
1,492
Chicago, IL, United States
I was hoping to get some advice as i have a blackout crank in nice shape and a little harder to replace .... any info for the BEST way to get it straight as possible this is bike and crank
Sep 2, 2012
12,595
Central Arizona
Somehow setting it up on a hydraulic press is the only way I can think of.
How does something like that even happen? Do whatever it was in reverse. ;)
Reactions: TieDye and JohnMast
the tinker
2,946
Planet Mongo
The exact thing happened to my 46 Columbia. I was having a problem with a pedal. I thought it was bent. The crank arm was bent, not the pedal. I removed the crank assembly and noticed the arms were offset, just like yours. I heated it up with a torch and tried to straighten it. I ended up tossing it and replaced. Either someone really heavy stood on the pedals, or a car hit it. Just replace it.
Sep 2, 2012
12,595
Central Arizona
I think that method was first introduced in West Virginia back in May of 1931. A loaded log wagon was used verses a van though. A little fine tuning can be done with a 20# sledge.
Craig Allen
Jun 23, 2016
188
66
Millville NJ
I would clamp it tight in a bench vise with brass jaws to keep it from getting marred, and then heat it at the crank/axle juncture with a torch to an orange color and carefully bend it back. You can slip a piece of steel tubing over the crank for leverage. As long as you keep the heat right there at the juncture you shouldn't have any problem with keeping the axle concentricity intact.
Reactions: JohnMast
