parkrndl
ok so I was all excited about this '64 girls' American I picked up over the weekend, but I noticed riding it that the pedals seem to come really close to the ground. So I measured it next to my '68 Panther, and it seems that the pedals are indeed an inch lower. The American has about 2" ground clearance from the tip of the crank at its lowest point, and the Panther has about 3" at the same point. Cranks are the same length as the Panther at 6.5" from the pedal centerline to the BB centerline. I started looking closer at my standard white garage door pic, then comparing it to pics I found online (several of which are from the CABE, as a matter of fact). Don't know if I am imaginging it, but it seems that the top tube and down tube come closer together on mine than in many of the pics I found. Can some of the more experienced Schwinn fanatics here tell by eyeballing a pic if the frame appears to be bent? Or is there a set of standard dimensions/measurements I can compare to? Thanks in advance...
