GenuineRides
What is the best method to straighten those bent pedal axles? This has been driving me crazy for years. I've accumulated all these decent pedals but many have bent axles, so I've swapped parts and am now left with a pile of bent ones. Since the bend is typically at the base of the threads because of the shaft being encased in the pedal frame (e.g. Torrington #10's) I've considered having a machine shop tap a long rod with both left and right hand threads on either end to use as a lever to bend them back. Pull the pedal apart, clamp the entire length of the shaft into a vice, thread this custom 15-18" rod onto the end, maybe apply a bit of heat and bend back into shape. I've tried the reverse, clamping the threaded end into the vice and slipping a pipe over the axle shaft but it seems the vice can never hold the short end tight enough to get enough leverage or I end up damaging something. Maybe someone here has the connections to make a tool or can provide this service for a cost??
GenuineRides
GenuineRides
