Just some thoughts on fabricating a Cycle Truck.
I would not start with a 24" wheel sized frame. Mainly because a 24" wheel almost always has a 28 hole hub. You want to start with a 26" wheel size (which has a 36 hole hub) frame donor. 24" tires are offered in less choices than 20" and 26" sizes. Having a high/low gear ratio is a big plus to have on a heavy bike. A Bendix two speed kick back hub is a great choice. No cables, shifters, or extra hardware. A yellow band would be a better choice over a red band because of the brake shoes over the disk's of the Red Band version.
You want to use a 20x2.125 "36 hole" rear Sting Ray rim to build your front wheel. You could even find matching Araya 7X anodized alloy 36 hole rims. They are common on BMX and Cruiser models. Their 1.75" sizing will still accept 2.125 width tires. They came in gold, silver, black, red, blue colors. A 36 hole large flange BMX front hub would work fine.
You would need to start with a 20" "true balloon" forged fork (not a middleweight Sting Ray fork). Ideally from a girls bike with the longer steerer tube. You would need a second girls fork for a second donor steerer tube. The two steel tubes would need to be sleeved and welded together. TIG welding is best for this type of work. You would also drill 1/4" holes in the area of the internal sleeve and plug weld the holes for extra strength. Use a piece of angle iron and four screw type hose clamps to hold the two pieces straight during the welding process. It would be good to have a buddy that had a lathe so you could fab your new tall head tube. You would need the lathe to cut the tube square and inside the correct I.D. for your head cups.
The connection of the head tube to the rear donor frame could be done with all straight tubes if you did not have access to any tube bending equipment. I would use 1" O.D. thin wall D.O.M. (drawn over mandrel) tubing. Most industrial metal stores sell what they call "drops". The DOM tubing comes in a lot of different diameters, and wall thicknesses. It bends, and welds nicely. It's best to scrounge through their scrap racks because the drops are "sold by the pound" which is a lot cheaper than ordering full 20 foot sticks. The frame tube welding could be TIG or even gas brazed with low temperature brass.
Shop for a 12" Superior stem, or even a 12" forged Wald. Wald made 12" stamped stems which are not as good as the forged stems. Make certain that you know the diameter of the tall stem you plan to use BEFORE you go to the trouble of extending the steerer tube. Early bikes are 7/8" diameter stems and forks. Bikes made after 1965 were reduced to 13/16" stems to allow the steerer tube thickness to be increased to prevent breaking. You could use either size, but you cannot mix them up.
It sounds like a fun project to me. You could easily fool 98% of even the Cycle Truck guys with some careful measurements.
John
