Bluemels Fender Stays (braces)
Vicious Cycle
I am looking for a set or several sets of Bluemels Fender Stays, They are the 3mm rods with a loop on one end, not the newer type with plastic ends. Please PM me if you can help. I could also use the later type "V" Stays that are all metal. Thanks
David
Andrew Gorman
Would the old ESGE struts work? There is a set on ebay as of 05/17/22. With a bending tool they are not hard to make yourself.
Tom Hand
David, I have my Bluemels fenders from 1974 if you need anything measured or photographed on them.
Vicious Cycle
I think the ESGE type are too short, The Bluemels attachment is much closer to the outside edge of the fender.
Gordon
I might have some but won't have time to check today. I'll look tomorrow and let you know.
Gordon
Here is what I have. A set of Esge with a small packet of hardware. From the center of the eyelet to the tip is approximately 13 3/4 inches. I also have a number of the continous loop ones. A pair of black, some chrome and some cad plated.
1629578
1629579
Tom Hand
I got mine down and took some photos and measurements for you. Front ones were 13.5" center to tip. Rear were 13.75". More next post.
Tom Hand
It would be very easy to fabricate these if you have a way to make the end circular bend.
