Brutuskend
First some theory.
I'm sure most people on here have seen a radial laced wheel. And maybe a 1 or 2 cross pattern.
Well, the fewer crosses used in a wheel, the shorter the spokes used. The shorter the spoke, the lighter the wheel will end up being. The lighter the wheel, the less energy it takes to spin it up and the less to stop it. However the fewer the number of crosses, the stiffer the ride will be. IE in a radial laced wheel, the spokes are pulling directly against each other and you end up with NO give at all. It seems most older wheels I see have a 4 cross pattern, which gives them a more flexy ride. The main down side to my way of thinking in a 4 cross lacing is, beside the added weight, that the head of the spokes end up getting trapped under the spoke on the opposite side, making spoke replacement when and if you brake a spoke very difficult.
Now, what is a symmetric and a asymetricly laced wheel?
When you build a wheel there are pull spokes and static spokes. If you look at the drive side of your rear wheel, and you look at the top of the hub, the spoke at the top, pointing towards the rear, is the pull spoke. The spokes pointing forward are the static spokes. When you pedal, the pull spokes are the ones that are taking the brunt of the stress being applied to the wheel. When a wheel is said to be symmetrically laced, that means that the heads of the pull spokes (and conversely the heads of the static spokes) will either all be heads in, or heads out. Why do this?
When you apply torque to the wheel if your wheel is not symmetrically laced, the wheel will have a tendency to want to flex to one side or the other. If it's laced "properly" the pull spokes will flex inward under load and not try to flex to the side.
What is interlacing?
Here is a picture of a Schwinn S-2 wheel that I haven't rebuilt.
If you notice, the pull spokes are heads in on the drive side and heads out on the non drive side. This is a asymetrically laced wheel. Now notice that the pull spokes cross over the top of all four spokes under them. This is a wheel that is NOT interlaced. In a correctly laced wheel, with a four cross lacing pattern, the pull spoke should cross over the top of the first 3 spokes, then cross under the last spoke. That is interlacing. This gives a wheel more latteral strength, and it will also make your wheel last longer.
Here is a wheel I built for my Elgin last week. Notice how the pull spokes are all heads out, and see how the spokes are over 3 and under 1 as they move from the hub to the rim? Also, if you want to get fancy, you can pick a label, or in this case a oil port and line it up with your valve.
I built a wheel at work today, and did a step by step pictorial of the whole process. I will post it along with instructions later. But I think I have rambled enough for now tonight.
ONE more thing before I go. On a front wheel, there really is no torque applied when you pedal, so for all practical intense and purposes all the spokes are static, so how you lace up a front wheel isn't really as important as how you lace a rear. Still, it never hurts to do both of them the "right" way.
