Congrats Jesper on getting that worked out. Any ideas yet on a possible year for this new beauty?
No idea as to the year yet. Original equipment, except I believe the crankset, 3t cockpit, and definitely the pedals are replacements. I am also dubious about the hubs (rear anyways) and freewheel due to missing spoke guard. Pump is stated as original, but that is a much newer (circa 70s-80s) SILCA pump; definitely not 40s. I need to get a better look at the Universal brakes (pre-Mod. 50/51 Extra; Mod. 39s?, BREV 361556, and not BREV 361666). There are 2 versions of the rod lever handle design; early version with a star, these are the later version with essentially the same design used on cable shift levers. There were 2 rod length variants: short set "Corsa", long set "Sport" (prior to '46 only 1 length; not sure which was earliest length). Note: my '53 Campy catalog states: "A richiesta si forniscono i cambi con le maniglie più lunghe per cicli de turismo" ("On request we can supply gearboxes with longer handles for touring cycles"); I don't know if that pertains the rod height or specifically to the rod handle section length. Missing spoke guard, but there a couple versions of it that would also have helped determine age (later was larger diameter; I believe to be used on the 19 tooth drop-out frame for 5 speed freewheels). I know it has the pre-1949 quick release design without "D" rings. I think the frame will be circa 1946-1948; maybe slightly earlier, but I doubt later than 1949. The drop-out tooth count is 17 versus 19, and it has a 4 speed freewheel.
