cant get screws off my shifter
Heraklinos92
Aug 3, 2017
12
5
37
New York, NY, United States
#1
pics provided show the problem. yes i used a screwdriver but wont turn. Did manage to get one screw off lol. what should i do?
1966fastbacks
May 17, 2015
223
193
TUCSON AZ
#2
I have had a lot of success spraying a small amount of wd40 around the edge of the screw head and letting it sit for +/- an hour then spray again and wait again.
2psps
34
13
Ontario, United States
#3
Definitely hit it with some wd40 a few times and let it sit . Make sure you're using the correct size screw driver so that you don't end up destroying the head of the screw. These require a thicker tip then you're average screwdriver.
I've had to drill one out due to the previous owner damaging the screw but that should definitely be your last resort.
1966fastbacks
May 17, 2015
223
193
TUCSON AZ
#4
Very true - screw driver size is the key
Ridge Rider
72
127
61
Ridgefield Washington
#5
I have a small cordless impact driver that I use on stuck screws and bolts. The impact action has loosened lots of screws that I was ready to give up on.
schwinnguyinohio
1,847
1,037
wilmington ohio
#6
trick we use on airplanes put valve grinding compound on tip of screwdriver just for a better bite on the screw
Andrew Gorman
2,676
620
#7
I like that idea! It also helps to be using a good screwdriver- they just fit the slot better. I have a set of Snap-Ons for difficult screws.
professor72
80
22
Dearborn, United States
#8
I would try aerokroil or other penetrating type spray first over a couple days. then using the right size screwdriver In the slot, give it a tap or two on the screwdriver handle top with a hammer and then try turning it. This usual works for me.
syclesavage
1,085
528
Middletown NY
#10
WD-40 and a good newer Phillips screwdriver. You may also try a lil heat in the form of a BIC lighter of equivalent.
stingrayjoe
1,957
573
Central NJ
#11
Old fashioned impact driver- the kind you rap with a hammer works well. The right size driver is key whatever way you go.
Pappy
Aug 31, 2010
318
80
61
Kansas City,MO.
#12
Use a correct size screwdriver with a wrench bung by the handle...then try tightening the screw a little first to break the corrosion.Use a wrench on the bung will give you better leverage & more control. You can twist til the heads bust off then deal with the studs left...
