MaxGlide
HI all,
Trying to take my Carter carb off for a service. I gotta pedal like crazy to get it going, seems like it doesn't fire until I pedal like crazy, then when I try to give it throttle it dies out. Even when warm, if the idle drops it stalls if i don't keep revving it a bit. Easier to get going once warm.
I figure I should give the carb a good clean.
SOOOO.... is there a trick to getting the carb off? Two bolts on the motor, the fuel line and throttle cable. Problem is the carb hits the motor bracket before I can get it off. Do I have to take the bracket off as well to get the carb off?
Pic shows the bowl butting against the bracket.
I appreciate any help you all can offer.
Wayne
Wayne
