But on a more positive note - It does look slightly better than the Packard Limousine some drunk put a ‘350 Chevy’ in, hacksawed off the top off over the front doors, put a Robin’s egg blue and white vinyl fishing boat interior in, and called a ‘Town Car’.
(That guy should be forced to ride this bike for TWO miles.)
To each their own….
Actually, if pulling up on the handlebars made the whole thing fold up into a rideable position that would be some pretty impressive engineering. But my eyes aren’t seeing that.
Impressive amount of work nonetheless.
I think if you air up the tires the chain ring might clear off the ground. But that won't attach the brake arm to the frame. You kinda need a free wheel rear cog so you can pedal ever so slightly backwards then ever so slightly forwards to propel the bike. If you are able to perform this trick your nuts (if you have any) will probably hurt for some time. Loving the front fender built with an erector set, but it needs a crane attachment or something to really set it off.
