Chain adjuster removal
VITAL.SPARK
Here is another problem I'm facing. As received one of the 2 chain adjuster's was broken off! in the past someone had made a slot and tried to remove it. The slot is stripped open so a screwdriver only slips off. There are a few threads sticking out the bottom. I was thinking of getting a nut tig welded on the bottom threads and grinding the slotted end down to try and get rid of any mushrooming, then trying the screw with welded nut out thru the axle slot? Suggestions please I do have an easy out set but this screw is tiny and my smallest easy out is too large!
