Chain Adjuster Screw
Freqman1
Jul 14, 2009
16,049
16,660
Evans, GA
#2
Some of the heads as well as length varies. The critical part though is the diameter and threading (TPI). V/r Shawn
abe lugo
1,458
439
Los Angeles,CA
#3
Threads are the main thing, if you have a tap/die set if has a thread gauge you can use that to see what TPI it is.
Or if yo have a bunch of old bolts just try some and see.
Then if you have a real hardware store, you can see if they have that thread/size in their bolts section.
You make shift some bolts or machine screws if you get the right TPI and length and have a lathe handy.
