juvela
by eye, the cycle appears to date from ~1973
note that the chainset is 144mm BCD rather than the 151mm BCD which was in use prior to the 1968-69 change
the rear hub quick release skewer is CPSC compliant which is too late for the machine
the front skewer cannot be seen clearly enough in the images provided to determine if it is date correct or also CPSC compliant
one check which could be made to see if the cycle's hubs are original to it would be to check the date on the inner face of the axle locknuts -
