Commuter build
Cooper S.
You guys might like this commuter build I did.
Nice build. Great color, love the shifter. How does it brake on the 700 wheels with the pads dropped down that far?
"Something old, something new, something borrowed, something blue", well maybe not anything borrowed.;)
Nice build!
one downside of staying with the original Tourney chainset for a single plateau drive train is that one is limited to the 52T chainwheel
usually for single plateau folks want to select something in the mid forties for a dentition
mounting instructions from the manufacturer suggest on these slant pantograph rear mechs to adust the angle such that the pantograph is parallel to the chainstay
stem binder has been replaced with a hardware store item. did the original fail?
thanks for any information
I set my gear ratio around the 52, which I’m quite used to riding 52s.
the derailleur is set up right, but I probably should invest in a chain guide.
I misplaced the original stem bolt so I got one from the hardware store lol, probably beefier than original
thanks for the response
the small cog looks 12 or less
you must be quite strong to be able to get good use of 52-12
few of us would be able to pedal that! :fearscream:
Well you’re not really supposed to use the lowest gear for just cruising, it’s much better suited to downhill and when you have serious momentum. I built it as a commuter/ delivery bike for college, so I’m probably a little bit more capable than almost cabers lol
