alecburns
Hey everyone,
I took on the task of relacing the rear rim of my '39/'41 Elgin with new spokes and nipples. I got the exact length spokes as the originals, and followed a tutorial that was posted on here. "Without the BullShlt. How to lace a 36 Spoke Rim". I followed the tutorial and what I thought the original lacing was exactly. I learned later that the wheels weren't originally interlaced, but I did that because the rim was slightly bent and I wanted to make it as stiff as possible (I know, this is debated). I was able to tension the spokes tight and true the rim just enough where I feel safe.
The problem I am having is that the threading of the spokes is past the nipple, and they are protruding into the tire space. I have searched to find a reason why, and the only thing I found to be a possibility is that the orientation of the rows is inverted (if that makes sense) on mine. In common rims, the holes surrounding the valve stem hole reads: top row, valve hole, lower row and on mine it is lower row, valve hole, upper row. Should I have done the lacing backwards to have the nipples thread on the spokes differently? What are my options? Should I unlace the rim and and lace them up to correspond correctly with the valve hole orientation? Or is there any issue with just filing down the excess threading after the 'bottom' of the nipples?
