bikemonkey
I can't tell if it's 2 or 3x from the pic with the hub in the way. If it's 2, you'll have to relace it.
If it is 3x, and the wheel is true, you can grind off the tips. That's common practice with any spoked wheel. I've built hundreds of wheels and almost always have to grind down a few spokes. The only time I've had to grind them all down was when I only had spokes that were a little too long.
Using a file will take you a week to grind them all down. Get a drill and a grinding bit. As long as there's enough threads to hold the nipple, it's fine.
As far as the wheel being previously bent, as long as it's not deformed from curb smashing, truing it will take it out without having to go to the extremes in the previous reply. Yes, it's easier to start with a perfectly flat rim, but if you know what you're doing, you can overcome that by truing it.
Also, if the spokes are only protruding on half the rim, you've got that half too tight, and it'll come out with a clown bike sizes hop.
If the spokes are that much too long you will run out of thread before you can tension the wheel - grinding off those spoke threads is absurd. If they are the same length as the originals then they will fit as good as the old ones. Do it right or don't do it.
I beg to differ on using bent rims. Your advice is unfounded and dangerous. I have been building wheels since 1973 and have decades in various bicycle shops. Is it possible to lace up a bent rim and get it close to true? - possibly - depends on the rim. Will the spoke tension be equal if you do so? - No, it will be crazy wrong - if you don't understand how critical that parameter is then you should not be giving advice on wheel building.
Should you do it? - never - unless you somehow straighten the rim first (unlikely) or you just want to use it for display.
If you want to run the risk of riding a weak and dangerous wheel, have at it, but frankly I would not advise others it's ok to do so, especially novice wheel builders. Have you ever seen what happens when a front wheel potato chips? Broken neck - paralysis anyone? Potato chipped rear wheels are perhaps not as dangerous - you will maybe just loose control at the worst possible moment.
Why are bent rims replaced when repairing damaged wheels? If you could use them over and over there would not be much use for new ones, would there? Do it right or don't do it.
