Convert 1973 Continental to Town Bike?
I assume you are meaning one piece to 3 piece crank? If so, the quick answer is no.
The 3 piece crank bottom bracket (frame) is threaded and smaller than the unthreaded 1 piece bottom bracket. I have seen adapters but there is an easier way if you are determined to do it.
The BMX vintage guys use a bearing set that allows one to put a 3 piece spindle in a one piece bottom bracket. Pretty simple all in all and still available on eBay. If you do this, do not use a cottered spindle. The square end spindle is a much better choice. I somehow manage to ruin the cotters in no time on British bicycles and motorcycles and have since high school. But then again, I could leg press 750 pounds at 16 so maybe I am a circus freak.
The one piece crank is dependable and bulletproof if it has a good waterproof grease and the bearings are good to start with. Plus it is cheap to maintain. Those are good selling points for the one piece crank.
I can help find one, should you decide to go this way and put you in touch so you can make your own deal.
Rob
the stock Schwinn rims are double layer sheet metal. Very heavy and very prone to getting dents from hitting potholes. Once dented the brakes will thump when the blips hit the brake pads. The double layer rims are hard to un-dent. Aluminum rims are so much lighther weight and really make the bike easier to ride. Also new aluminum rims will be the correct size so fitting new 27" tires isn't a big hassle. 700c may also fit if the brakes have enough adjustment room left. There is a lot more tire selection in 700c vs 27". 27" is pretty much just 27x 1 & 1/4" and nothing else. 700c is availabe nearly any size form 23mm to 50mm. You can run a wider tire (that will clear the frame). A wider tire can usually handle potholes, seams and cracks in the concrete, etc, better.
FYI, Schwinn 1-piece cranks have 28tpi bearing threading. The rest of industry uses 24tpi threading. There are some aftermarket bbs that have seals to try to protect the bearings. Although I've seen plenty of bikes with seals that do a far better job of keeping water in. You can also buy caged bearings for 1 piece cranks with 8, 9, 10, 11, or 12 balls in the cages. More contact points spreads the loads out so they should last longer.
Changing to a 3 piece crank has a number of measurement issues that will frustrate first timers. A too long axle will put the 3 piece sprockets out so far the derailleur can't reach to shift in to high gear. Too short and you can get chain suck so bad you can't get the chain out. Each brand/ model of crank will require a different length axle. Trial and error is the easiest way to sort it out but not if you have to buy the test fit parts. The stock derailleur is a 'road double' meant for 2 chainrings only with a 39-52 tooth range. It's tempting to put on a mtb triple crank but then you need a mtb triple derailleur with a clamp size that won't fit the skinny 1" seat tube on the Schwinn ef frame. Most bikes have 1 & 1/8" seat tubes or larger.
Welcome to the CABE, old bike (nut) guy!
What color do you plan to paint it?
I would recommend choosing a primer spray can similar to the final finish spray paint color.
That way hides chips and scratches better.
Also, some nice brown tones will hide rust, and there are some spray paint primers in similar brownish colors. Remember, some bikes thieves may think that it’s okay to steal a rusty bike, because, after all, it’s rusty.
First steps might be a regular handle bars arrangement, like for normal people, and a seat (aka. saddle) with big comfortable springs, fenders (aka. mud guards), a rear rack, lights, and a regular kick stand, (if it does not have one).
Later, one might figure out how to fit wider and more comfortable tires/wheels, in order to cushion the ride.
https://thecabe.com/forum/threads/replace-1970s-vintage-bottom-bracket-with-square-taper.208622/
QUIZ: What is a binomial gear number?
Heck yes, you can convert to a 3 piece crank. There are at least twenty different threads over on https://www.bikeforums.net
which give complete details on how someone converted their SUPER SPORT, or more lowly CONTINENTAL / VARSITY.
Why would you even want to do away with the NEVER PROBLEMATIC, BULLET PROOF, Ashtabula 1 Piece CRANK?
You don't need to reduce weight! The only reason to consider the 3 piece is to make the bike lighter.
The CONTINENTAL is a boat anchor.
You would reduce weight by perhaps one pound.
You are building a tourist bike, not a racing style bike, so a pound or two isn't going to matter.
A much more serious concern however is the overall gear range that you employ if you are converting to
a five speed set up with a single front chainwheel and the stock '73 Continental (model F, 14-28 ) freewheel.
A much much better choice would be the (shimano, japanese built model J, 14-32) freewheel which is on the SUBURBAN
5 speeds (1970 -1976) and on the 1970 - 1977 COLLEGIATE five speed models. The late sixties and seventies era
VARSITY/CONTINENTAL and '64-'69 Collegiate have the same (model F, 14-28) freewheel.
The 10 speed SUBURBAN has the same (model F, 14-28) freewheel, as the SUBURBAN 10 speed is simply an UPGRADED VARSITY Tourist model, as the Suburban 10 speed is exactly like the Varsity except that the Suburban has the tubular front fork of the Continental. The Varsity Tourist's final year was 1969. Suburban made its debut in 1970.
You will seriously need to consider what LOW GEAR that you have in order to climb hills more successfully. The 1964-1969 COLLEGIATE is awful in hill climbing in comparison to any 1970 - 1977 COLLEGIATE.
The Europeans could not produce a rear derailleur that could reliably shift anything larger than a 28 cog.
The Huret Allvit that Schwinn employed was perhaps one of the Europeans best in terms of functionality and reliability but it was still second rate by a country mile to the Japanese rear derailleurs. Schwinn began using Shimano specifically on the 1970 SUBURBAN 5 speed and the 1970 COLLEGIATE 5 speed.
Formula to Calculate GEAR NUMBER:
Number of TEETH on Front Sproket is the NUMERATOR
Number of TEETH on Rear Sprocket is the DENOMINATOR
Example:
bike has 27 inch wheel(630mm)
45 teeth Front Sprocket
15 teeth Rear Sprocket
45 divided by 15 = 'result'
Now take the 'result' and MULTIPLY x wheel diameter = GEAR NUMBER
Depending on what wheels that your bike has, YOU WILL USE either 27 or 26 as your wheel diameter
As a rule if your bike is 27 (630mm) or 700C (622mm), YOU WILL USE 27 for the wheel diameter.
As a rule if your bike is 26 (597mm) or (590mm), (584mm) (571mm) or (559mm), YOU WILL USE 26 as wheel diameter.
Example continued:
take 'result' and multiply x wheel diameter = GEAR NUMBER
45 divided by 15 = 3
3 x 27 = 81 GEAR
********** This simple calculation WILL GIVE YOU OUTSTANDING COMPARATIVE Gear Numbers BETWEEN SIMILAR BIKES**
As you know, you can IMPROVE Low Gearing in a couple of ways:
You can GO with a LARGER REAR COG, assuming no change to the front chain ring.
You can GO with a SMALLER FRONT CHAIN RING, assuming no change to the REAR COG.
Now, of course, you certainly can do a combination of both if you want to, within allowable limits.
Now, you certainly know that reducing the single FRONT CHAIN RING (making the front chain ring Smaller) WILL REDUCE THE TOP-SPEED POTENTIAL of said bike, assuming the rider could make full use of that potential in the first place.
So you do need to recognize that because that realistically does limit how practically small that you would want to go on the single front chain ring
Here is something to consider, assuming that you convert that '73 Continental to 5 speed with the existing 14-28 freewheel.
It is my opinion that You Would Need to find a 42T front chain ring for the Ashtabula 1 piece Crank IN ORDER TO GET YOU MINIMALLY DECENT ENOUGH HILL CLIMBING, as well as decent enough practical & useable Top End gear.
(42)
14-16-20-24-28-Model F freewheel on Continental/Varsity/10spSUBURBANs
81-71-57-47-41-GEAR NUMBERs(already calculated for you based on 42 teeth front)
As you can see below, the SUBURBAN 5 speed with 14-32 Model J freewheel and stock 46T front chainring
(46T)
14-17-21-26-32-Model J freewheel on SUBURBAN 5 speed
89-73-59-48-39-GEAR NUMBERs
As you can see below, the 1970 - 1977 COLLEGIATE 5 speed with 14-32 Model J freewheel and stock 46T front
(46T)
14-17-21-26-32-Model J freewheel on 1970-1977 COLLEGIATE 5 speed
85-70-57-46-37-GEAR NUMBERs
The CONTINENTAL/VARSITY/10spSuburban 52/39 front with 14-28 Model F freewheel
(39T small ring)
75-66-53-44-38-GEAR NUMBERs
(52T Large front ring)
.14-16-20-24-28-Model F freewheel
100-88-70-58-50-GEAR NUMBERs
***As you can clearly see, THE 1970-1977 COLLEGIATE has better HILL CLIMBING Ability than the Conti/Varsity/10spSUB
Yes, that is right because 37 GEAR NUMBER is better than 38 GEAR NUMBER as far as hill climbing ability!!
Though the SUBURBAN 5 speed DOES HAVE THE SAME 14-32 freewheel and 46T front as the 1970 -1977 COLLEGIATE, the reason that the '70-'77 Collegiate calculates a 37 GEAR NUMBER while the Suburban 5 speed calculates a 39 GEAR NUMBER is because the Collegiate has 26 inch (597mm) wheels and the Suburban has 27 inch (630mm) wheels.
Now, do you remember that I said earlier that the 1964-1969 COLLEGIATE has AWFUL Hill Climbing in relation to the '70-'77.
1964-1969 collegiate with 14-28 model F freewheel*
(46 T front chainring)
14-16-20-24-28-Model F freewheel on '64-'69 Collegiate
85-75-60-50-43-GEAR NUMBERs
***As you can clearly see that 43 GEAR of the 1964-1969 Collegiate is AWFUL when compared to the 37 GEAR of the 1970-1977 Collegiate
NOW JUST FOR THE HECK OF IT, What will you have if you just Go with the single 46T schwinn front chainring on a stock CONTINENTAL/VARSITY/or 10 sp Suburban with 14-28 model F freewheel
(46 T front chain ring)
14-16-20-24-28-Model F freewheel on late sixties and seventies era CONTINENTAL/VARSITY and seventies SUB 10 speed.
89-78-62-52-44-GEAR NUMBERs
***As you can see that IF YOU JUST Go with the single 46T schwinn front chainring when converting a CONTINENTAL or VARSITY or 10 speed SUB. , YOU WILL END UP WITH A RELATIVELY HORRIBLE 44 GEAR NUMBER for hill climbing.
Hey, the numbers don't lie.
Do calculations before you proceed, UNLESS you live in an area where everything is as flat as a billiard table.
(This is WHY that I suggested that you consider choosing a 42 TEETH front chainring as it will give you a 41 GEAR lowest gear that would be minimally adequate for Hills.)
******IN MY OPINION, useful Gearing, WILL MATTER A HECKUVA LOT MORE THAN WHETHER THE DANG BIKE HAS A 1 piece Crank OR A 3 piece Crank. You would be stupid in my opinion to change out the 1 piece crank!
The #64 SCHWINN CAGED BEARINGS are fantastic. Clean them with a 30 min soak in about two ounces of Formula 87 in a cut in half aluminum Coke or Beer can. Formula 87 is 87 octane, same thing that powers your lawnmower and car.
THEN LIBERALLY REPACK the two #64 caged bearings WITH synthetic, waterproof "GREEN GREASE" (thats a brand name, company's out of Texas) available at auto parts stores in a 14 oz plastic cylinder cartridge, that you can open and spoon out what you'll need and the close it up and store the huge remaining amount. Cost is ten bucks at NAPA and AUTOZONE, the other auto parts store chains will be approximately 0.85 to 1.50 more in pricing on Green Grease. You cannot find a better grease for the 1 piece bottom bracket at any price. Now, having said that, realistically any ordinary military spec automobile/vehicle grease from 1939 or 1943 will do the job..........it will require re-greasing much more frequently but a bicycle doesn't spin the bearings anywhere near how an autobile wheel axle does, so it is not that critical, only that you do use a liberal amount of clean new grease, no matter if its from a can of grease from World War II era. If you have to buy grease for the job anyway, my suggestion is go for the synthetic waterproof "Green Grease" or something compareable, as the cost is not much considering the 14oz quantity that you do get.
Whatever you do decide, there is a practical solution for you.
Do calculate the gearing that you think you will require.
Nothing is worse than having a bike that you otherwise like but that is a real bear to climb a hill with.
Be smart and do it like you were the factory engineer.
Heck, you have so many possible front chainwheels that you can use on the 1 piece ashtabula Schwinn crank.
Now, do remember that IF you do go with a rear freewheel that has anything larger than a 28 cog, YOU WILL NEED TO EMPLOY A shimano OR maedaSUNTOUR rear derailleur that can shift a 32 or 34 cog.
The shimano built GT-100 schwinn approved rear derailleur(1970-1973 suburban 5 speed & 1970-1973 Collegiate)
and the shimano built GT-120 schwinn approved rear derailleur(1974-'77 five speed Suburbans & Collegiates)
These shimano built GT-100 and GT-120, were occasionally installed on Varsity/continentals when the Chicago factory production line was out of the Huret Allvits that ordinarily were installed on to Varsity/continentals.
Count yourself lucky if you own a Varsity with the shimano built rear derailleur as the Allvit is second rate in comparison to the shimano.
Now, I recommend that when anyone converts any ten speed from drop bars to tourist handlebars, that they should GO With the 7881 Schwinn handlebars, which in my opinion are the best ever made, as far as shape, width, rise, and overall comfort.
I have converted about 35 various ten and twelve speeds using the 7881 Schwinn bars exclusively. Many of those 35 bikes were indeed other makes' 10 speeds, but on every single converted bicycle that I have done, I use ONLY the WEINMANN-diacompe Aluminum Alloy 22.2m TOURIST BRAKE LEVERS as found on various SCHWINNS between about 1964 and 1979/'80. I have used RED DOT knife edge, RED DOT ball end, ORANGE DOT ball end.......they are all functionally the same. I don't care as long as they are clean and look nice enough. So yes, I've installed maybe more valuable RED DOT knife edge levers from a circa '65 Schwinn on to an early eighties Sears Free Spirit that I converted from drop bars to 1967-1977 Schwinn 7881 handlebars. These Weinman TOURIST BRAKE LEVERS of the sixties and seventies are extremely durable and they are very simple to install and mount, utilizing a very user friendly FLATHEAD SCREW for tightening/loosening.
The BELL PITCREW 600 Cable set is the best buy that you can make if you change from drop bars to tourist bars, or if you just need to replace any or all cables. NOW, YOU WILL NEED TO CHANGE THE BRAKE CABLES WHEN YOU SWITCH FROM drop bars TO tourist bars with Tourist Levers BECAUSE THE Brakes on DROP BARS utilize a mushroom bullet like cable end, WHILE THE Tourist Levers utilize a cable end that is shaped like an Adult ASPIRIN tablet.
The Bell Pitcrew 600 Cable set comes with the aluminum ferrules that are perfect shape, fit, and look for those ancient Weinmann Tourist Brake Levers (you know where the cable exists from the Weinmann tourist Lever...that Ferrule is included in the BELL 600 Cable set......you get two of them.......so you need not worry if the used set of Weinmann Tourist Brake Levers actually have those ferrules included with them from your ebay or cabe source.
You will need a Brake Cable cutter and BIKESMITHS has a no name red colored one for approx $16 that is identical in shape, and design as the much more expensive Pedro's and Park Tool brake cable cutters. It works just as good. It may not last as long but I have done over thirty five bikes with this $16 tool, so I would say that there is no reason to pay more.
The Bell Pitcrew 600 Cable set sells for around $10 or $11 and Ace Hardware has it ONLINE (not in Ace stores) and Walmart online, and some Walmart stores carry it in store, and you'll surely find other online vendors that carry the BELL PITCREW 600 Cable set.
I hope this information is helpful in your Conversion To 5 speed Tourist Model.
The ancient electroforged Schwinns make fantastic Tourist style riders, with 7881 handlebars and your favorite spring saddle tourist seat. Again, I would urge you to keep the 1 piece Ashtabula crank on that bike. You'll never ever break it and you'll have no problems ever with it, because everything is easily available, should you need to replace the #64 caged bearings or the cups etc. You have decent quality new Taiwan manufacture replacements, or you can use used near perfect original Schwinn that with a cleaning and good waterproof synthetic grease will probably still be going strong in the year 2127, or at a minimum many thousand miles.
If going for looks and style i would simply add fenders and a tourist bar set up. if you want lightweight and still some style, I would get a 70's or 80's butted steel diamond frame with generous clearances, use wide 700c wheels/tires/long reach brakes, add fenders and aluminum tourist bar/stem combo
A simple and easy option that I have done on all my road bikes since a teen; 1970 with Schwinns and still do on my Treks. . Yet baffles my imagination as to why most everybody else who are NOT actual competitive racers buy them.
I mean, I put 100's and 100's of miles speeding 20-30 miles to the beach and back and daily riding for transportation, work, school etc. Up hills down, every thing, every where. And all my road bikes even now.
Yet, the public are all acting as if they are competition racers while drop bars hurt their backs. Crazy!
Surprised even now that I took a lot of searching to find one photographed.
Looks odd is all but, you can relax better when turned up-side-down. Maneuverability at a fingers touch. Rather than squeeze to brake; push forward. Ride with no hands and or, use brake handles to steer, it's a breeze. Rather then bending into the bars you can push and pull in many different angles including when you'll need more power to get up a hill, rising up, standing on your feet and grabbing bars to pull is easier.
The standard set is aerodynamic, right. Yet, unless you are actually racing then it's a real pain in the back!
Flip em like this albeit, I tilt mine a little higher so I can pull on the top ends, verses level, and you've got much more comfort, means to control, power and more as a city, country or distance rider:
Totally agree with OldBikeGuy on the bottom bracket. The cup and cone design, well packed with grease, can handle a lot of weather. My college bike lived outside for 4 years in the rain and it never had a bearing problem. It was pretty rusty at the end of five years, but I gave it to a grad student when I left and guessing he got a couple more years out of it.
The problem with these old lightweights is that nobody seems to want them anymore. Index shifters and the comfortable grips on those new shifters makes our old Schwinns undesirable to most people nowadays. Plus as someone pointed out, the comfort bikes, mountain bikes and hybrids are the bikes of choice for most these days. Except for serious roadies, nobody rides drop bar bikes. I just refurbished a 1973 Varsity a few weeks ago and can’t find any buyers for that bike after putting about 10 hours into it and $50 in new rubber.
I did convert my sister’s old Panasonic to flat bars a couple of years ago. I had an old kid’s mountain bike that someone dumped on the curb and salvaged the bar and brake handles from that bike for a free conversion kit. It works fine, even though my sis never uses it. I ride it when I visit her.
I’ve built up a few city bikes. I’d do it in phases. Phase 1: simply slap on some upright bars, along with the cable, brakes and grips.
Ride that for a bit. then decide:
  • do you need to swap the seat?
  • how’s the braking and tires? A 700c conversion might be smart. Pay attention to axle lengths and hub widths. If you go this route a bump to six or seven speeds might be an easy upgrade.
  • if I upgraded to 7 in the rear I’d probably keep the one piece crank but pare back to a single chain wheel and no from derailleur.
at that point it’d be a pretty good city bike, I think
