szathmarig
Here we have is a 1936 "Flat tank" Roadmaster that almost never comes up for sale, so this might be your only chance to own one. This bike is far from perfect, so here is a list of the bad.
Frame is bent at the head tube, both the top, and the down tubes are bent, and as a result of that the tank doesn't fit right, and I couldn't install the head badge because the badge suppose to go over the tank. The tank has 3 extra holes that someone drilled. One bigger one, and two smaller ones. The trims on the tank are reproductions. The chain stays are crushed by a kick stand. The fork is for a tankless model without the V shaped truss rods bracket. This fork is actually harder to find. The correct fork would be the flying V fork which is easy to find.
If you need more pictures, let me know.
