PlasticNerd
Iām making reproduction cork gaskets for the Delta Silverray lights. These go between the lens and the cone/reflector that houses the light bulb. They are within .020ā of several old ones I had. They are easily replaced with a bit of care. Remove the two screws that hold the face bezel on. Then, remove the bezel and very carefully twist the flat bars in either direction to remove the reflector from the two flat tabs. Replace the gasket after removing broken cork, if itās still there!!! Then set lens on top of the gasket, set in place on the front bezel, THEN, very carefully twist the flat tabs back into their respective slots, being careful to not break them. Put light back together and enjoy a sealed beam again!! Discount available on 5 + . Please DM to purchase-Gary
