ReVo
Here is another little mod I've been making on my typhoon project. I got a rough delta torpedo fender light with a fender set I bought here on the cabe. The case was a tad messed up and the reflector lens was toast. It did still work, but I wanted something a bit more reliable and cost affective for batteries so I decided to convert it to led.
I started by looking online to see if anyone else sold a kit or had plans to do this... That was a failed attempt... So in the name of science and adventure and all that jazz I set out in search of parts. I went to a local department store and picked through all the 3 volt led flashlights they had and found one which had a lens of the same size as the fender light. Then came the fun part. I dissected the flashlight and stole the bulb and lens.
After much tinkering and a few failed attempts at salvaging the ground switch system I opted for a new age solid state switch from radio shack. I drilled two holes in the main case for it where the ground switch used to be. I then fabricated a new ground terminal which will be riveted on after paint. I also had to modify the innards as well. I moved the front spring piece back to help accommodate the longer bulb. I also disabled the case ground system with electrical tape. A bit of soldering later and I had a working light!
I'm only in about 15 bucks as it stands, too. I'm excited to get the rest of the bike painted and back together so I can throw this on!
-Ron-
-Ron-
