Schwinny
I was looking at a near perfect vintage headlamp and the only thing wrong with it in any way is a pinky nail size dent on the underside. Out of the way and cant be seen unless you look up from underneath. A spoon would probably do fine to push it out, but it had been there a long time and was next to a rivet holding on an internal part so not easy to get a good angle on.
I thought back to a way Ive know to take care of dent like this with no marks and nearly a perfect removal sans any divit at the strike point that may have been created. The dent will be gone.
This will work on bicycle tube dents. May even help to straighten a frame.
Many folks dont know about this technique but it is nothing more than a high school science experiment.
Water expands, If there is a dent in something such as a tube or hollow like a can or bowl, you can just fill the void with water and as the water freezes, it will expand the metal back to its original formed shape without marks. the more confined the space the more pressure will be exerted, but it will take from 4 to 20 times in the freezer.
Ive got the headlamp in there on its 5th freeze cycle now and about half of the dent is gone.
I will post a before and after pic when its done.
Fingers crossed.....
Before pic is the best of 8...uhg.
