Differences
AS-1
What are the differences between a 1955 Jaguar frame and a 1955 Corvette frame?
SJ_BIKER
Riding a 41 Super Deluxe
Jag takes wider rims/tires- heavy weight frame and Corvette is a middleweight frame
AS-1
Thank you! If I measure in between the chain stays just at the edge of the rim, what will the 2 measurements be? In pounds, how much heavier is the Jaguar?
SJ_BIKER
Heavy weight at top fender mount is nearly 4"
And middleweight see pic
AS-1
I can check and get back
Thank you for the help!
Something is not right. The measurement between the seatstays up at the curved fender bracket (like in your second picture) on my early '50s balloon frames is only 3 inches. The measurement down at the chainstays from side to side at the face of the rim is 3 3/16". Can you check the measurements on a 1955 Jaguar and a 1955 Corvette for differences?
