Disassembling and removing paint from the 1960 Schwinn Jaguar
ArborlyMink
How do I disassemble a 1960 Schwinn Jaguar and what would I do to remove the paint from it
Disassembly of most bikes is pretty much the same and bead blasting is how I like to remove paint. V/r Shawn
Is there an easier way to remove it lol
That is the easiest way. You can use chemical stripper, sand, or wire wheel but those are fairly labor intensive. If you don't have a blasting cabinet look for a local place and have them do it. V/r Shawn EDIT---If that's the bike why would you want to strip that? The bike will clean up remarkably well with a little elbow grease.
