Hastings
Schwinn S2 front wheel. Has the front brake hub. Axle feels straight threads are good nuts are a little rounded off but usable. Spins reasonably true for an old wheel. Definitely not bent up or hopped or anything like that. Only flaw that should be noted was it looks like they use a little bit too much heat when they welded the hoop joint ‘like a little too much melted man’ see picture. I don’t think it affects the performance at all it’s just noticeable when you run your finger around the rim. Chrome looks pretty good underneath the old paint job. Paint job comes off easily with goof off. Rim was left with the patina finish but it will definitely clean up as you would expect it would. Some spokes are loose needs some maintenance. Add $32 for shipping US 48 only PayPal friends and family or money orders thank you!
