Dressing Bad Welds
FSH
Aug 27, 2018
458
Corona
I got my bike about a year ago and ever since then the Helen Keller of a weld job has been bugging me. So I decided to pull out some tools and spend a few hours getting the weld presentable. it's a work in progress and I hope to be done this week so I'll post as many pictures as I can of the process. This is what it looked like before I got started.
FSH
Aug 27, 2018
458
Corona
This is the during process. I used a specialized flex shaft grinder that I'll post a picture of shortly, and two specialty burrs. There was a lot of material so consequently there were allot of shards flying around and I had to spend a few minutes pulling out splinters from my hands. The material came off more easily than expected and luckily I had a finishing burr available. I plan on using a mini drum sander and a vibrating sander finish up the process. It was important for me to leave consistent fillet around the periphery of the tube, so great care was taken during the semi finishing process. If you notice there are some inclusions that became present during the cleanup process, however, I do not believe these will affects the overall strength of the braze.
AndyA
Nov 24, 2017
203
72
bergen county
FSH:
Metal splinters in your hands? The Safety Committee is disappointed. Please, when grinding take the time to wear hand protection (leather or kevlar gloves) and eye protection (safety glasses or face shield). If you think a metal splinter in the hand is painful, you don't want to think about one in the eye. As Sergeant Esterhaus said on Hill Street Blues, "Let's be careful out there."
Reactions: WetDogGraphix
FSH
Aug 27, 2018
458
Corona
FSH:
I agree with eye protection of course, however, I avoid working with gloves when using rotating elements.
fordmike65
Riding a '37 Colson Imperial
Mar 4, 2012
21,164
East Los
Reactions: FSH
AndyA
Nov 24, 2017
203
72
bergen county
FSH:
Your concern about the potential of gloves acting as "loose clothing" around rotating elements is valid. However, that concern typically relates to larger tools like lathes and jointers, where a glove could be pulled into the tool. I don't think that the small grinders that you are using on this project present that sort of hazard. It's great that we are discussing safety matters on this forum. Have fun!
FSH
Aug 27, 2018
458
Corona
FSH:
I have been machining for about 30 years and have gotten countless splinters, small cuts, and small burns. Sometimes this is the price we pay when attempting to achieve aesthetically pleasing and mechanically sound results. Thus, when dressing welds the practitioner must rely on touch and sight as the prevailing senses. Gloves, however well intentioned, hamper the ability to achieve correct feel and are therefore ill-advised when doing such delicate work... Splinters generally won't kill you, they are at most an inconvenience.
FSH
Aug 27, 2018
458
Corona
not to pick nits but that is not a weld.
If you read my earlier post you will see that I address the metal joining on my bike as braze. The dressing process I undertook would be the same for both braze or weld. So, at least in this case, the terms weld and braze are interchangable.
