Durkopp chainless
bikejunk
Nov 1, 2014
791
57
passaic NJ
My Hershey find this year #s relate to about 1915 (WW1) every thing is marked durkopp except front hub --a very early drum brake and not matching rim up front though the correct size . Years ago the bike got a new seat and a caliper brake on the back wheel .rear wooden rim takes clincher tires 28. X1 1/2 fit nice .
bikejunk
Nov 1, 2014
791
57
passaic NJ
front hub is nickel plated rear hub has a few internal parts disabling the brake but the rest of it runs smooth I would like to find a correct seat I have a rim to match the rear clincher rim
yan.kun0567
May 26, 2019
10
34
Düsseldorf, Germany
Nice find. Most likely you will have to find a Hammock saddle which looks like in the attached picture. This is the German standard saddle, nearly all bicycles were equipped with from around 1905 till 1933. But be aware, these got quite rare in Germany too and are hard to find. But as this is most likely an export model, maybe Durkopp used a saddle more common in the area the bike was exported to. So a Christy Saddle could be a fitting choice.
Is the rear hub a Torpedo? If so, you can date the bike easly by disassembling the hub. Each part in the inside should be marked with 09 F&S XX (xx is the year of production).
bikejunk
Nov 1, 2014
791
57
passaic NJ
Thank you for the information on the hub also about the seat
