elusive S-4 Baloon tire
rennfaron
There was an S-4 for a short period in the 50s. It came on the welterweight and tandems (which is why the heavy duty spokes).
Either way the seller doesn't care because I messaged them and said that's not a "baloon" tire, it's specific to two models. No update to the listing.
Attached: "Rims: Schwinn built, tubular, chrome plated, S-4"
rennfaron
I thought they changed out at some point in the 50s. I looked at the '61 catalog and it still says S-4 for the tandem/T&C. I thought you would see more S-4 rims turn up, but I guess the tandems were still pretty low numbers in production compared to all others.
rustjunkie
Moderator
I messaged this guy to explain never was a S-4 and that he has a S-7 and he is looking at the 7 upside sown and the S is the start of the next Schwinn marking. Either doesn't know or doesn't care. Don't miss out on this one of a kind baloon tire hahahaha
looks like straight-gauge spokes and a 1950s new departure hub, the ad @rennfaron posted specs morrow, but nd was likely available as well
The S-4 is on the 1948 Tandem specs and that was probably the first year for that rim. The highest T&C serial number that I've come across was a high 5K number. They used the tandems pre-stamped BB shells on many of the early post war lightweights so the actual number produced was nowhere near 5000.
coasterbrakejunkie1969
I did not know that, I'm learning. Did the S-4 have knurling like that? What is the difference between S-4 and S-7? Did the S-4 use a standard tire or Schwinn specific?
rustjunkie
Moderator
what hub was typically on the tandems?
rennfaron
Yep they had knurling like shown in that ebay link you posted. There are some early 50s S-6 rims that have that same knurling pattern.
No idea on difference because I don't collect any bikes with S-7s. @GTs58 I am sure knows.
At the time these are the tires you got on them. Hard to find.
