Fauber crank
RichH
Looking for a Fauber Special crank arm.Crank does not need to be shiny new just not welded and good threads if you have caps with good threads would be interested in those also.Thanks
zedsn
Hi, mine says fauber special on the chain ring and can't see it on the crank arm anywhere but it is a bayonet crank and is a fauber special with good threads. The chain ring minus the teeth is 8" and I doubt that there are too many of these laying around. It would be $16 shipped if you wanted it. Ed from Ohio.
