Folding bike stand Question
BLWNMNY
1,332
1,947
Stockton, Ca.
#1
I know we probably all use different variations of bike stands, some might have them mounted to the wall, work bench etc. I use a fold up version so I can put it away or move it out in the yard, my question is , What fold up stand do some of you use that you feel is sturdy enough for you for working on these old heavy bikes? What brand and model do you recommend personally that works well for you?
Likes: gkeep
bairdco
1,883
2,159
Midway
#2
I have a Pedros folding stand. And it's the best I've used.
The squeezy-trigger grip is easier and faster to clamp a bike. Much better than the worm-gear screw type most stands use. It doesn't slip, and will clamp any size round tube, and most oval and oversized tubes.
I use it everyday, all day, assembling bikes at walmarts, and it'll hold 99.9% of bikes.
The clamp easily swivels to any angle, to grab a seat post, seat tube, top tube, etc.
It also has a quick release thumb button so you're not fidgeting with the release while holding onto a bike.
You can change clamp positions in seconds, so it's ideal for bike assembly work.
It has held all of my heavy ballooners with no problems. And you can adjust the position of the bike easily, even if it's partially assembled and off balance, like if you've got a heavy springer front end and you take the back wheel off, it won't slip or flip over.
Folds up about as compact as you can hope for, and I've had thousands of bikes on it (about 30-40 a day) and all the moveable parts are still tight and functional.
So, that's my testimonial...
vincev
Nov 2, 2008
11,145
6,573
crown point<indiana
#5
I like my Parks.stand.The legs lay flat on the floor so you are not tripping over them and it easily folds up if you need to take it down.I have had heavy motorized bike in it and it works great.
Likes: Ed Minas
BLWNMNY
1,332
1,947
Stockton, Ca.
#6
Which model do you have?
7,883
5,269
Central Arizona
#8
I went fairly cheap years ago and choose the Park pcs-9. Works fine and I had my 53 Phantom clamped in it for a looong time. :eek:
vincev
Nov 2, 2008
11,145
6,573
crown point<indiana
#10
Once you work from a stand you will never want to be without one again
bairdco
1,883
2,159
Midway
#11
I agree. It's so much easier to do everything your bike requires, without flipping it over, sitting on the floor, whatever.
I've done motorized bikes on my pedro stand, too. It'll handle 70lbs or more without slipping.
The only complaint I have, is the top brace is aluminum. So magnetic trays don't stick.
Likes: WetDogGraphix
Boris
Feb 16, 2008
10,835
4,840
Portland, OR 97206
#12
A friend of mine GAVE me an almost new Feedback Pro Elite with tool tray. Wasn't really looking for a tripod style because of the floor space required to put it up, but it folds down nice and compact so it doesn't take up very much room when stored. I just set it up outside if I need the stand to work on a bike. A well made stand that's very sturdy, and I'm happy to have it. A $250 stand for free? I sure ain't gonna kick about that.
Clark58mx
Oct 30, 2016
370
778
25
Brookfield, United States
#13
I have two Park Tool PCS-4. No issues with this stand. I have even used it to help support a Whizzer, while changing the front tire.
Kickstand3
May 16, 2014
707
994
Grapevine Tx
#14
Those are great stands
Sent from my iPhone using Tapatalk Pro
$275.00
$26.80
$6.99
$124.99
$9.95
$39.99
$20.00
$325.00
$160.00
$1.99
$30.00
$69.00
$15.00
$44.95
$199.00
$175.00
$79.00
$18.00
