Fork spreader?
B
Boardtrackfan
Guest
I'm kinda new to the pre-1933 bikes so, I have a question about mounting the front wheel. Most of the early bikes I have just have a hole in the bottom of the fork blade, not a open ended slot. Some of the early hubs I have are not threaded all the way across making it seem impossible to mount the wheel. I do have a catalog from the early 1900s that shows a "fork spreader". Is this what I am supposed to do to mount these wheels? I don't want to cut any of my early forks and I'm not to thrilled about spreading/bending them either. Am I just putting the wrong type of wheel on? Help!
The fork spreader.
eat your wheaties
and grab both and pull apart:D
not easy but works
Best method I have found is to lay the bike down flat on the ground or a blanket. Insert the lower protruding axel of the wheel wheel into the fork leg nearest the ground. Push down on the wheel and hold it steady and pull up on the upper fork leg until you can work that over the top axel. Dont worry about bending the fork as they are quite springy.
