Fork with Open Closed Drop-Out
bleedingfingers
I'm Going with both methods stretch it or cut it .
If the bike was some Holy Grail original paint item that might be different but you can always weld a piece back in .
It will be way easier to change tires fix flats etc . if you cut it .
If you do stretch it it shouldn't break but there's always a chance that it might or may crack .
I have one on one of my bikes that after stripping several layers of old paint off was cracked in 3 places probably from being stretched over many decades of tire changes .
The forks I've have are closed on both ends and the hubs do not have lock nuts on the cones .
kunzog
Fork Spreader
Rivnut
maybe you can find an axle that's threaded end to end.
Probably a 5/16” x 24 TPI. Unles you’re totally committed to 100.00% original, you can buy a complete axle with bearings, adjusters, washers, and nuts for not much $. You might be able to pick up some all-thread and custom make an axle the length you want that you can thread all the way into one adjuster. My tap and die set has the correct die for a non Schwinn axle. Double nut one end of you axle, clamp it into our vice and cut threads to the existing threads on the other end. You might be lucky and have the two match when they meet, but don’t count on it. I have a 1935 Elgin with a similar fork. I also have a nice cutoff wheel. I’m thinking about changing flats in the future, maybe while on the road.
Rides4Fun
Thank you for your suggestions, Rivnut. These are very helpful and I appreciate you taking the time to share your insights!
